1 - 7 of 7 Posts
Good morning Gents, had a hack work on the Saab and I'm trying to get it back into shape. I had a code 21 and 06.. Found three connectors hanging loose under the dash. One fixed the 06, there is one left. Anyone know where it should be connected? the red and yellow connector, realized and green/black is the glovebox. Thanks!
Current: 2000 9-3 Aero 5d, Family: 85 900i 3dr.
Without knowing more context :
Car model,
I was doing this <eg audio work>
I suggest you consult the WIS as it has wire diagrams and pin locations.
The WIS will only help when the car is in factory state also
if someone has replaced xyz wires....
It is also possible the wires are for an RHD or LHD option or accessory.
Thanks for the WIS, it's a 1999 Saab SE LHD Vert. I had a 21 and 06 error ac code. I suspect the remaining 21 is from something left disconnected as the controller motor was.
1 - 7 of 7 Posts
