well the picture certainly look correct
yet wheel bearing needs to be good quality manufactured though
i bought mine from local motor factors and turned out seems to be excess stock from saab
on the assumption that
the abs ring was branded same make as the original (vdu)
and the bearing housing was same brand as original (***)
and lastly inside the housing the stamped part number also had a sign of deburring tool removing a stamp same size as i think the saab logo and name were stamped
but i was happy enough just seeing the oem makers parts used the same as one i removed
I recently (last few weeks) had to replace my rear passenger side wheel hub. I ordered for the same ebay user detroitaxel. The part is the right one, fit no problem but I had a bad sensor. I called them and they sent a new one out right away, which had a good sensor and has been doing just fine.
Personally I was skeptical also as they were and ebay seller, and were way cheaper than any where else even close to me & online. But it all worked out, I would recommend them.
