1 - 8 of 8 Posts
Strangest thing, I turn the wheel and it creaks, go over bumps it creaks, I raised the car off the ground to look at it... It creaked!
Yet I cant see where there creaking is from.
Any ideas?
Thanks!
Thanks! That is what I was hoping. I just bought 2, these where cheap enough.
Piece by piece trying to make this car dependable again!
MMy mechanic did it, well beyond my ability. Actually had it done 3 times now, each time had the same symptoms, noise when turning and going over bumps.
Thats one in a million case, if it was the cause actually.
Because u saying u already replaced it 3 times, that tells me its something else that the mechanic touch during the axle replacement which make the noise disappear for a while, but not the shaft ..
also did strut bearings and sway bar, control arms prior to the axle shaft being replaced. Each step it got better, but fully solved with the axle being replaced.
1 - 8 of 8 Posts
