I need to get steelies for winter and tires for winter.
I have a 9-3 Linear, with 17 inch rims from Saab 5spoke ones. Currently i have 225/45/R17
The guy said.. i should of had 15 inch rims? ?
So.. he told me for winter i should have 195/60/R15 iam worried about the clearence for the brakes..
but then agian Good year said 215/60/r15
all on 15x16 5-110 steelie rims
15s ok for winter? cause orignally.. Kal tire told us.. 15s are not good on my Saab. due to brake clearence..?
It depends. What model year is your Linear? If it's 2003, then 15" is ok. Look in the manual for approved wheel sizes. I know that when I bought rims and tires for my 2003 Arc, TireRack believed 15" would fit, but the Arc and Vector had larger brakes and 16" was required.
I think at some later point Saab switched the Linear to larger brakes, but I don't know when. Again, if the manual lists 15" as allowed, you should be fine. You'll know soon enough when you go to mount the rims - if they're too small, it won't even go on.
Here in Filnlad we drive from November to May with winter tires and sometimes we have a lot of snow. I have 205/55-16" (Saab original ALU43 10-spoke) and they are ok, no problems at all. So I suggest to take 16", because 15" not looks as good as 16" and 17" are too hard.
crosscheck here: http://www.rims-n-tires.com/info_specs.jsp
