Next year i will be hopefully sending my 9000 aero for an overhaul , major tune i have a full 3 " jt exhaust already and saabflight ecu , but what should i get for my cash ? car has done 190.000 miles , but runs great
so i suppose and engine rebuild would be in order but what should be done etc?
You can try getting a racblock or a tranny from maptun. THat's what I would do...
Klim
Do you mean overhaul of base parts or £5k budget for tuning?
If £5k is split between tuning and overhaul, you'll need to tell us what you have done already tuning wise. (or are you saying it's only ECU and JT?)
Ok - Here's my hitlist after a couple of years of armchair surfing... this is actually my car spec give or take a bit.
Suspension:
Abbott springs £200
Konis £400
Speedparts Front strut brace: £130
SAS rear ARB , or Abbott rear piggy back: £170
Front arm rear butterfly bushes (powerflex purple): £70
Front ARB poly bushes £15
Engine torque arm bushes poweflex yellow - £44
Gearbox mounting bush - powerflex yellow - £30
Engine: Upgrade to Maptun Stage5 - 340bhp / 375ftlbs
Rebuild your 15T to 18T. £400
Green giant injectors - £150 (US import)
ITG airfilter: £45
Forge Dump valve: £90
Forge wastegate actuator: £100
3 Bar map sensor: £50
Uprated clutch (Sachs or Spec 2) - £500odd
Remap : £500
Uprated I/C: £400 odd
LSD and gearbox rebuild £1200
Brakes:
Set of brembo grey iron discs: £90
Ferodo DS2500 pads all round: £160
Braided lines: £70
That lot is about £4400 and inlcudes ZIP for labour...
Next rung up would be:
GT28RS turbo with Siemens injectors and Walbro pump. (360+ bhp)
Bigger wheels to accomodate much bigger brakes.
Budget well blown by then on parts alone.
5k will get you a back to metal respray to fix all that rust lurking in the doors ,under the bodykit ,at the back panel etc etc
trust me I know....
