1 - 7 of 7 Posts
Hi Guys,
i am planning on the weekend to remove the rear seats and side panels in my convertible.
I want to try and goto the hardware store today and get the relevent torx bits etc. i will need, anyone know what torx #'s would be handy to have when working on the car? (i know there is the torx screwdriver in the kit, but i would prefer to not bugger that one up :D)
I cant remember the exact size, but its pretty much a standard size thats found in the torx bits / screw driver heads set that you can pick up for a few pounds nowadays. Ill check on the exact size later.
If you want any install photos for the 'vert i have a whole load that you should find usefull.
Edit.. This is the set i have and come in pretty handy with the Saab
http://www.jaycar.com.au/productView.asp?ID=TD2035
No probs - ill send them later!
The install is slightly easier than the saloon because you can tap into the wires under the back seat, but you do need small hands when bolting the speakers in to the back seats!.
I did do a full step by step instruction but lost it when my pc blew:roll: .
I'm pretty sure the one in the kit is a T35. That's the one for the license plate screws, Cylinder head cover, etc...
1 - 7 of 7 Posts
