1 - 13 of 13 Posts
Hi all this might be a stupid question but what would I buy for a rear shocks "rebuild" mine are rotted bad and I am wondering what exactly I would need. Any info is helpful thanks
I have a 07 combi 2.0T
Buy OEM-quality upper mounts (Sachs). I have had the cheaper mounts fail on me, catastrophically once, over 1.000km from home.
Depends... IF like me.. I usually replace anything in the area that looks suspect. Too often: everything.
In the hope that I won't be immediately surprised by something else nearby failing.
Do you want to keep the car reliable.. or is this a short term patch job?
I'm trying to make sure that I have to never do this again pretty much so I want it to be reliable
2007 9-3 2.8T estate
Nothing to rebuild, only to replace. Assuming you have a front wheel drive only, you'll need number: 8, 10, 16 and 15.
White Product Font Auto part Parallel
Discussion Starter · #11 ·
Changing just the rear shocks is a very easy job, so I wouldn't worry about it too much.
No I'm not worried about that I've done them many times on other cars I'm just wondering what parts I need for doing the springs and shocks
Yep. As above, just the shocks and the mounts.
If you're doing the springs as well then I would definitely recommend you buy new top and bottom seats for the springs. Number 8 and 10 in the above diagram.
Also start spraying everything now with penetrating oil.
Discussion Starter · #13 ·
Ya good idea thanks for the info
1 - 13 of 13 Posts
