I've read a lot of different threads on what size wheels to put on the 92x Aero for winter tires. I want to go 16'' but everybody always refer to the bolt pattern: 5 X 100. OK that's settled but nowhere can I get a confirmation on the offset. Can anybody answer that?:roll:
thanks
You can find 15" steelies for cheap. The advantage is that they are cheap and you won't mind getting them a little dirty in the snow.
I've seen someone mention that 15" steelies + Blizzaks can be had for $500 or so.
When the snow melts, put the BBS wheels back on :D
53mm offset is ideal.
thanks
anything between 48mm and 55mm will fit fine (6.5 - 7" wheel width) and go with 205/55R16 snows.
