1 - 20 of 21 Posts
So, now that I got the car, what should my first mod be?
A boost gauge is on order, but what should I do for my first power mod?
Thinking... Cold Air Intake?
I don't want to spend a ton of money just YET
On a side note, I demolished my tires pulling onto a highway today. One tire fire for about 100 feet :D
I thought I told you that was bad for your tranny. :roll: Personally I think you should do the suspension up so it'll put down the power you have more effectively, but an open element intake is always fun. Won't really net you any power, but the noise is awesome. WHOOOOOOOOOOSH-PSSST! It's surprisingly addictive and costs under 100 to do. :cheesy:
Raven18940 said:
I thought I told you that was bad for your tranny. :roll: :
I didn't actually mean to do it. I rolled into the clutch with almost no power (slow start) then I gunned the throttle in 2nd and the tires totally broke traction for about a hundred feet or so.
Road was a bit dusty. That had ALOT to do with it.
I'd say mesh grille mod and open air filter mod. SImply because they are the easiest and cheapest mods.... good for a start.
well, what i say is get an new exhaust and intake. and you must upgrade the ECU. that is a must for real power. or if you want, you can just take you car to hirsch or find out actually what they do in their package and do it yourself. 305hp, not bad. not bad at all. i don't know how much it will cost, though.
http://www.saab-performance.com/GB_en/2_3_engine.html
well, whatever you decide to do with it, i saw your pics, and it is amazing!!! great car, and stock, they are hella fast. so you should be good with anything that you do with it.
aero1116 said:
Exhaust and downpipe. Of course, then you need to do the ecu too. :cool:
Do a search and you'll find endless debates on this topic. Software or Hardware first???
I think it depends on the supplier, but I know on some to get full advantage of hardware, you can get your software programmed for it.
Do a search, and you'll find a weeks worth of info that will make you lose your mind :eek:
Hirsch isn't available in the USA......:confused: :roll:
im planning on buying what i can from BSR and taking it down to the saab specialist in my area. See if you have a specilaist and then go talk to him about it.
Whats the budget for your first mod?
Are you thinking, styling or performance :confused:
do the brakes first, no point having all that power without being able to stop. i know you might not like the idea but it makes total sense, i've done it suspension next so it will handle better. then finally the woosh. can't wait till end october for suspension to be done after my hols:cheesy:
Discussion Starter · #15 ·
I dunno, the Aero brakes and suspension are pretty good right now
I'm want a performance mod... trying to stay under $150 right now.
Open air filter :cool:
I assume you have clear side repeaters ;)
Not smoked but Crystal :cool: :cool:
Discussion Starter · #17 ·
No, orange.
But I'm going to be spraying them with Niteshades spray tint to make it black
There arn't any performance mods for under $150.......:roll:
Are you sure you didn't mean $1500......;)
Tell me about it. :cheesy:
1 - 20 of 21 Posts
