Matt,mucky said:It looks like Saab offers the Sti short shift kit for our car. Do I need this or would something like the kartboy work. Thse two seem to be totally different designs. How can I tell if I have the Sti version 5MT?
Thanks,
Matt
Thanks,
Matt
I should have waited for you to install it firstnotyou said:Install was a snap. I have a bit of advice to offer to those following the scoobymods instructions (linked in Trinifry's informative posts). Rather than bang on the new lever with a mallet to force it into the socket, use leverage instead:
notyou said:Well worth the cost
I would assume they're the same, but if you look here at the Saab one: http://www.saabcatalog.com/retail/category.asp?catalog%5Fname=Saab+Catalog&category%5Fname=Drive9395%3A9%2D2X+Short+Shift+Gear+Lever&Page=1kutch said:-Hummm, I asked aren't they the same exact thing?:nono;
-Well they look the same sir, but this ones from Saab...:roll: :roll:
How does the Kartboy knob feel? I was planning on buying the entire kit from the Kartboy site, including the bushings. For $150, that isn't bad, considering buying it all seperately elsewhere would be around $180-190. The knob looked to be of pretty good quality, and bigger is better for me. My 6'5" self has huge hands and I don't want a puny knob. Thanks.notyou said:Just bought and installed the Kartboy shifter and knob. I'll be installing the bushings this weekend. A very nice improvement. Feels very solid and precise and, somehow, these characteristics translate to the rest of the car. It's not possible, but the car feels faster. Can't wait to see what the bushings do...
...Well worth the cost.
No such thing. The STi has a 6-speed.mucky said:How can I tell if I have the Sti version 5MT?
I bought the STi SS for $286 from subarugenuineparts.com and had it installed with my boost and oil temp gauges for $400. I'm not sure how much just the SS install would have been but the majority of the $400 install cost was due to the difficulty of the gauge install. In my opinion the Sti SS is the way to go just because it replaces the linkages, your not just buying a shorter lever which in my opinion isn't really a shorter throw, you just get the feeling of a shorter throw because of a shorter shift lever. Yes, the Kartboy is cheaper but that's because you don't get as much as you do with the Sti. Can't really compare the two.Trinifry said:Matt,
I have installed the Kartboy SS into my 9-2x. You can get more information about this from the following thread:
http://www.saabcentral.com/forums/showthread.php?t=42193
The STi SS package comes together with the full shift assembly while the kartboy SS comes only with the lever. They both offer significant improvements in shorten throw however the STi SS costs more and requires more work to install. If you are buying the STi SS and getting it installed at a dealer, be prepared to spend lots of $$$. The kartboy is cheaper and can be installed relatively easy.
Hope this answers you questions.
Jeff
You can purchase an Sti SSK for the Wrx in 5 speed format. Its also available for the Aero, I had it installed about 2 weeks after I bought the car.jdmpartstx said:To answer this question:
Thanks for the info!omahawk said:If anyone else does this you will need a metric 12mm x 1.25mm tap and die.
