I'm looking through the service records for the 1992 9000 Turbo I bought yesterday and there's reference to three "recalls" having been performed:
708
284
289
I assume these are service bulletin numbers.
Does anyone know what work was performed?
Recalls for 1992:
Office of Defects Investigation (ODI)
Recalls - Search Results
4 Records Displayed.
Report Date : November 23, 2007 at 09:00 AM
SEARCH TYPE : VEHICLE
Make : SAAB
Model : 9000
Make : SAAB Model : 9000 Year : 1992
Manufacturer : SAAB CARS USA, INC.
NHTSA CAMPAIGN ID Number : 94V029000 Mfr's Report Date : FEB 03, 1994
Component: FUEL SYSTEM, GASOLINE
Potential Number Of Units Affected : 5824
Summary:
THE FUEL FILLER AND TANK VENTILATION HOSES MAY DEVELOP CRACKS UNDER THE SECURING HOSE CLAMPS, RESULTING IN FUEL LEAKAGE.
Consequence:
FUEL LEAKS MAY RESULT IN A FIRE IF AN IGNITION SOURCEIS PRESENT.
Remedy:
THE FUEL FILLER AND FUEL VENTILATION HOSES WILL BE REPLACED WITH NEW HOSES. THE FIVE SECURING HOSE CLAMPS WILL BE REPLACED BY A NEW TYPE WITH A SHIELD THAT PREVENTS DAMAGE TO THE HOSE WHEN TIGHTENED.
Notes:
SYSTEM: FUEL; FUEL SYSTEMS. VEHICLE DESCRIPTION: PASSENGER CARS. NOTE: IF YOUR VEHICLE IS PRESENTED TO AN AUTHORIZED DEALER ON AN AGREED UPON SERVICE DATE AND THE REMEDY IS NOT PROVIDED WITHIN A REASONABLE TIME AND FREE OF CHARGE OR THE REMEDY DOES NOT CORRECT THE DEFECT OR NONCOMPLIANCE, PLEASE CONTACT SAAB SERVICE CENTER AT 1-800-955-9007. ALSO, CONTACT THE NATIONAL HIGHWAY TRAFFIC SAFETY ADMINISTRATION'S AUTO SAFETY HOTLINE AT 1-800-424-9393.
NHTSA CAMPAIGN ID Number : 94V126000 Mfr's Report Date : JUL 06, 1994
Component: ENGINE AND ENGINE COOLING:COOLING SYSTEM
Potential Number Of Units Affected : 12040
Summary:
DURING LOW ENERGY FRONTAL IMPACT COLLISIONS, THE FRONT CROSSMEMBER CAN CONTACT THE METAL TUBING PORTION OF THE COOLER HOSE ASSEMBLY; AND/OR THE HOSE ASSEMBLY CAN BREAK AND LEAK OIL ONTO THE HOT EXHAUST MANIFOLD OR THE TURBOCHARGER.
Consequence:
OIL LEAKING ON THESE HOT ENGINE SURFACES CAN IGNITE AND CAUSE A VEHICULAR FIRE.
Remedy:
DEALERS WILL INSTALL A PROTECTIVE COVER WHICH WILL PROTECT THE COOLER AND HOSES FROM OTHER STRUCTURAL COMPONENTS IN LOW ENERGY FRONT IMPACTS.
Notes:
SYSTEM: ENGINE COOLING SYSTEM. VEHICLE DESCRIPTION: PASSENGER CARS EQUIPPED WITH ENGINE OIL COOLERS. NOTE: IF YOUR VEHICLE IS PRESENTED TO AN AUTHORIZED DEALER ON AN AGREED UPON SERVICE DATE AND THE REMEDY IS NOT PROVIDED WITHIN A REASONABLE TIME AND FREE OF CHARGE OR THE REMEDY DOES NOT CORRECT THE DEFECTS OR NONCOMPLIANCE, PLEASE CONTACT SAAB SERVICE CENTER AT 1-800-955-9007. ALSO, CONTACT THE NATIONAL HIGHWAY TRAFFIC SAFETY ADMINISTRATION'S AUTO SAFETY HOTLINE AT 1-800-424-9393.
NHTSA CAMPAIGN ID Number : 95V067000 Mfr's Report Date : MAR 20, 1995
Component: SERVICE BRAKES, HYDRAULIC:ANTILOCK:CONTROL UNIT/MODULE
Potential Number Of Units Affected : 12091
Summary:
MOISTURE CAN FOLLOW THE ELECTRICAL HARNESS AND ENTER THE PRESSURE SWITCH CONNECTOR CAUSING CORROSION AND MALFUNCTION OF THE SWITCH.
Consequence:
THE CORROSION CAUSES A DETERIORATION OF THE ELECTRICALSWITCH CONNECTION AND CAN RESULT IN FALSE ILLUMINATION OF ABS AND/OR THE BRAKE WARNING LIGHTS AND/OR THE LOSS OF POWER ASSISTANCE BECAUSE OF NO HYDRAULIC PUMPOPERATION. LOSS OF POWER ASSIST INCREASES THE DRIVER'S BRAKE PEDAL EFFORT REQUIRED FOR STOPPING WHICH CAN RESULT IN EXTENDED BRAKING DISTANCES.
Remedy:
DEALERS WILL INSPECT THE ELECTRICAL CONNECTIONS TO THE ABS PRESSURE SWITCH TERMINALS FOR CORROSION AND INSTALL A SHRINK HOSE TO THE WIRING HARNESS TO AVOID MOISTURE ENTERING THE CONNECTION. PRESSURE SWITCHES WITH CORRODED CONNECTORS WILL BE REPLACED.
Notes:
SYSTEM: BRAKES; HYDRAULIC; ANTI-SKID SYSTEM. VEHICLE DESCRIPTION: PASSENGER VEHICLES EQUIPPED WITH "MK II" ANTI-LOCK BRAKING SYSTEM (ABS) BRAKES. NOTE: IF YOUR VEHICLE IS PRESENTED TO AN AUTHORIZED DEALER ON AN AGREED UPON SERVICE DATE AND THE REMEDY IS NOT PROVIDED FREE OF CHARGE WITHIN A REASONABLE TIME, PLEASE CONTACT SAAB AT 1-800-955-9007. ALSO CONTACT THE NATIONAL HIGHWAY TRAFFIC SAFETY ADMINISTRATION'S AUTO SAFETY HOTLINE AT 1-800-424-9393.
NHTSA CAMPAIGN ID Number : 99V109000 Mfr's Report Date : MAY 01, 1999
Component: AIR BAGS:FRONTAL:SENSOR/CONTROL MODULE
Potential Number Of Units Affected : 26116
Summary:
VEHICLE DESCRIPTION: PASSENGER VEHICLES. MOISTURE CAN ENTER THE AIR BAG INFLATABLE RESTRAINT ELECTRONIC CONTROL MODULE (ECM) AND CAUSE CORROSION ON PORTIONS OF THE ECM PRINTER CIRCUIT BOARDS.
Consequence:
THIS CORROSION CAN POSSIBLY CREATE OPEN CONNECTIONS IN CIRCUITS WHICH CONTROL THE RESTRAINT DEPLOYMENT, POSSIBLY CAUSING INADVERTENT AIR BAG DEPLOYMENT.
Remedy:
DEALERS WILL INSPECT THE EXTERIOR OF THE ECM. IF THERE IS NO INDICATION OF MOISTURE, A COVER WILL BE INSTALLED OVER THE ECM. IF THERE IS INDICATION OF MOISTURE, THE DEALER WILL REPLACE THE ECM AND INSTALL A COVER OVER THE NEW ECM.
Notes:
OWNER NOTIFICATION BEGAN JULY 5, 1999. OWNERS WHO TAKE THEIR VEHICLES TO AN AUTHORIZED DEALER ON AN AGREED UPON SERVICE DATE AND DO NOT RECEIVE THE FREE REMEDY WITHIN A REASONABLE TIME SHOULD CONTACT SAAB AT 1-800-955-9007. ALSO CONTACT THE NATIONAL HIGHWAY TRAFFIC SAFETY ADMINISTRATION'S AUTO SAFETY HOTLINE AT 1-888-DASH-2-DOT (1-888-327-4236).
