1 - 20 of 34 Posts
what other bolt on parts are there for my car... that i dont have????
inlet pipe... and fmic??? is that all??
i remember reading somewhere that a b205r head already flows better than others, the intake manifold is ok....
the ic will b on its way in the next week or so...i am dynoing on tuesday i think so tht will give me something to compare with.. as long as my car isnt running too lean.. otherwise i dunno what i will do ;oops:
Where are you gonna dyno on tuesday rico?Bristoldyno?Are you getting the mp intercooler or a different one?
I just installed that thing and I definitely notice an improvement.Spool up time decreased slightly and it definitely pulls even harder now.I can't wait to dyno this *****.Boost seems to have went up slightly also.before,was 1.6 bar (23.5 psi).Judging from my memory function on greddy gauge,max hit was 1.65 bar which is like 24.2 psi!
Discussion Starter #6
i am dynoing at bristol dyno i believe on tuesday. He is having a special right now 40$ for 3 runs with a/f
ricot I am really curious about your AF ratios and also power. Me also being a t7 auto.
I figure even though you are getting power that "theory" says should not be there:lol: ;) , that you might eventually need an ECU to supply more fuel to the mix as you have lots of airflow mods... please keep us posted.
ricot83 said:
an ecu will not give me more fuel, injectors and an fpr will
I don't know about that. I definitely blow through way more gas when I hammer on my car with my stage 1 than when I hammer on it with the stock ECU. :confused:
Are you saying I get that much extra power (approx +55HP) without the ECU adding extra fuel? I know it does more than just advance the timing a little.:lol:
Discussion Starter #11
no thats not what i meant dan but i m sure u understand...
jeff i am just thinkin what else i can do to get a little more power out of it without ecu :confused:
I think unless you don't have a full 3" turbo to tail exhuast you might be at the end of what you can do without SW, and still gain without any... dare I mention this...Downward adaptation. :eek: :lol: you seem to have all the major mods covered already.
ouch.
Are you still undecided on whether or not to get the ecu or not ricot? Or are you gonna wait til your next dyno run?
Discussion Starter #20
lol ya... well people said that the limit of the td04-15t is like 300bhp.... and i hfind that extremely hard to believe so i am going to see what i can squeezt outta my car and the turbo b4 needing any kind of software
i was actually just thinking about it and if our fuel systems can really only hold up to 300bhp like i have also read, then with the new fmic i should be right around there...
1 - 20 of 34 Posts
