Hello, I'm planing to do a fluid change because it has probably never been done. But i've read on the Swedish forums that the newest oil isn't good for the older transmissions (syncros) and they recommend normal conventional motor oil instead. Any thoughts?
Thanks in advance!
Skickat från min SM-G965F via Tapatalk
Manual or automatic?
Automatic: Dextron III or something that meets the DEX III specs., do not use motor oil
Manual: use the GM/Saab manual transmission oil. IIRC the number is MTF063 or something like that.
Manual. I've read several threads about the never GM spec oil is bad in the non updated transmissions.
