1 - 7 of 7 Posts
Hi I’m very new to Saab’s but very much enjoying the car. I have an 89 900 16v turbo. I’ve owned it for about a year, trying to sort out the many things that are not working! The other day I noticed a leak from the radiator goose neck to reservoir which I guess will require a replacement but I noticed this part. The connector is very brittle and the wires had come off. Can someone tell me what this is and which way the wires should go!? It sits on top of the radiator..
Any info appreciated!
Boost pressure control valve. You now have only base boost.
Thanks guys. The connector broke apart. Is there polarity to this? Not sure which one goes the back wire and which one goes the white !?
Discussion Starter #6
Ok got it. I noticed when I connect it, it continually makes a relay like noise. Is that normal? I didn’t remember hearing this before. It happens even if I swap the connection of the wires and is the same.
1 - 7 of 7 Posts
