Greetings:
Is there practical method regarding the checking and or greasing of the cv joints? Could be added/inserted without removing the boots or what? Also are the ball joints/tie rod ends equipped with grease fittings? What say you?:)
Best Regards
91 900se turbo 16v/2.0 174,000 plus original!
If the driveline joints go around and around smoothly, and the boots are still in one piece, chances are they are properly lubed. The ball- joints do not come with grease nipples, if they are worn out replace them.
