What happen with my engine cooling system?
lots of steam came out from the engine bay
and the SID displayed "FILL COOLANT FLUID"
which part of the system is broken?
THANK YOU
If its not obvious then you ned to fill it up and carefully watch it heat up, or have a pressure test done.
Check your hoses and coolant bypass valve. I just replaced the bypass valve on my 99 9.5 and it did the trick. you can find the part for about $30 and it takes maybe an hour to do. Theres a great link on this forum that shows the process.
