1 - 10 of 10 Posts
G
hello i have been reading the WIS and i keep coming across +15 or +30 for certain fuses going to the TWICE, does +15 mean it carries a positive 15 volt DC? any idea? thanks and when they mention I bus (+) and I bus (-) is that run on its on system or is the (-) the ground? thanks guys
+15 is switched power(turns on with the ignition)
+30 is continuous power(stays on all the time)
G
thank you very much, that helps a ton. would the WIS say anything about voltage in a specific wire?
Wis
Folks:
I need electrical diagram for a 2003 95. WIS has it, I know. My question is where to get it? I have a weird problem with the fuel pump relay buzzing and need to follow each wire. Thanks,
Did you try swapping out the relay? And checking all related fuses?
Folks:
Buzzing fuel pump relay
Yes, of course. Replaced both fuel pump relay, Ignition relay (I think), ignition switch, FUEL pump! fuse 14 and 15, checked all others and same weird problem. Have a friend going through each wire, but she was working fine before quitting... Do not know what to think:evil:
To answer the last question, before the hijack....
Normally you won't see a specific voltage reading listed for a specific wire in the wiring diagrams. +15 and +30 are just some industry conventions for denoting supply wires that come directly from battery (+30, power is there at all times that battery is connecte in the vehicle) and from ignition (+15).
There are some ranges for voltages in the text for trouble-shooting, but not on the wiring diagram.
Plus 30 and plus 15
Hello
+15, means when you have the ignition key on the accesories position
+ 30, means the voltage on the system have the alternator charging then the engine is running to charge the batteries few minutes the cranking was past.
Someone know how ISO or ANSI standar have this conventional values?
1 - 10 of 10 Posts
