2161 - 2168 of 2168 Posts
I've got my cylinder head stripped to be resurfaced
Have just finished ordering some necessary parts today, $ in Australian,
Head gasket was almost fully blocked with copper stop leak rubbish from the previous owner.
Parts ordered $673
Automatic shift cable bushing upgrade $57
Timing chain tensioner washer seal $10
Exhaust manifold gasket $40
Valve stem seals $43
Serpentine belt $30
Head gasket $54
Head bolts $74
Thermostat $30
Pcv grommet $13
Oil filter $12
Inlet manifold gaskets $25
Carby/Brake cleaner, degreaser $40
Scrapper/brushes $20
Machining $100
Valve seat lapper $10
Seat lapping compound $15
Fluids $100
Tools order $160
Torque wrench $40
Torx sockets $35
Valve spring COMPRESSOR $62
Valve stem pliers $12
My coolant reservoir cap fell apart, so while replacing it I also added an overflow tube that extends below the car. The stock tube was just 12”. No more overflow on the back of my engine and firewall!
Sent from my iPhone using Tapatalk
After adding an Alpine amp and some Saab/Pioneer 6x9 woofers to the rear deck, I still wanted more kick down low. So I went the next step. I discovered an infinite baffle design called a 'ski pass-through infinite baffle' on some bimmer forum. I had a spare channel on the amp, and a sub that just happened to be good for infinite baffle, so I threw one together. It's not pretty, more of a proof-of-concept.
271162
There's a thick foam gasket between the baffle and the back of the seat. Wedged between the floor and with a lip on the top against the steel, it's totally friction-fit. Meaning I can still fold down the back seats and move this out of the way to haul big things when needed.
Still looking around to see if I can remove the plastic pass-through door without damaging anything, though.
271163
I also ordered the last of the items needed for my upcoming clutch replacement.
