It's very unusual to find a seat heat or cooling switch with both bulbs working.Tried to restore the lighting of the seat heater controls. Learned that a) I hate those bulb sockets and b) one of the controls won't see any light again, so I hope that another used one will be able to illuminate me.
Getting them little buggers out was no problem...fitting the new ones back in was a PITA. Took me some time to realize that a certain amount of force was needed, and the slit could have been grooved a tad bit deeper.It's very unusual to find a seat heat or cooling switch with both bulbs working.
A flat screwdriver of the right blade size can typically remove the bulb on its tip.
You need the proper flat screwdriver blade. The bulbs wedge on the tip of the blade. Then you insert and lock the bulbs.Getting them little buggers out was no problem...fitting the new ones back in was a PITA. Took me some time to realize that a certain amount of force was needed, and the slit could have been grooved a tad bit deeper.
To follow this up, during the trip I added 54.88 litres, and at the end topped off with 25.20 litres. So 80.08 litres total.Not today, Monday. Took a bit of a trip. I haven't reconciled the fuel usage with what SID is showing, though.
I presume that the old sockets were dried out (they were quite brittle) and had shrunken a little bit while the new ones were not fitting 100% (made in China?) and the plastic was rather soft. That's why I had to use a certain amount of force to push them in until they seated correct.You need the proper flat screwdriver blade. The bulbs wedge on the tip of the blade. Then you insert and lock the bulbs.
They also appear fairly delicate in my experience, so applying force isn't a good thing.
I hate that job on the 9-5. I can do it in about an hour but I’m always cursing the engineer who designed it this way. Every other car I’ve had, the cabin air filter is a literal 5 minute job.Guess where I was today?
What an absolute cow of a job that is. Done it before on a previous 9-5 and I've been putting this one off since I bought the car.
Certainly needed doing though as the old filter was filthy. And the last person who changed it obviously had fun too going on the state of the foam seal. A rotten foam concertina at one end.
Hating that on the Zafira A and going to dread it when I'm going for the filter in spring. Guess that one engineer at GM had also sought his fun at kicking the neighbours dog and stealing the change from his kids piggy bank.Guess where I was today?
I've run a few Lexus in the past and I don't think they're even 5 minutes. Open the glovebox and there's a little door at the back. Voila.I hate that job on the 9-5. I can do it in about an hour but I’m always cursing the engineer who designed it this way. Every other car I’ve had, the cabin air filter is a literal 5 minute job.
The forum guys who claim they can do it in 15 minutes are clearly lying. I don’t think a NASCAR pit crew could do it in 15 minutes.
I feel ya, bro...in the Zafira, there was a damn metal strut in the way which took off a good deal of skin in the process of changing the filter. Lying on the floor contorting myself in a manner I never thought I was capable of didn't lifted my spirit either.I've run a few Lexus in the past and I don't think they're even 5 minutes. Open the glovebox and there's a little door at the back. Voila.
My back's feeling it today. I'd say you're about right with the hour. Took me longer with all the procrastinating, tea drinking and having to stand up when I get cramp in my leg![]()
Thanks for the warning in advance.Added fun was having to do it in a fairly narrow garage and because mine's an auto the bloody gearbox ECU (?) is in the way. At least I learned from the mistakes I made on my previous 9-5 and didn't stick the foam to the top of the filter and then try and slide it in.
Trick is to remove the old filter, foam and debris then fit the foam in place with the cut outs around the pipes. Then slide the filter in using something to hold on to/lift the foam so it doesn't snag on the filter and fall off or get pushed to the bottom end.Thanks for the warning in advance.![]()
Cool, what mechanical mods have you done to your car?Just shipped my ECU to Mike D, for either stg3 or 4 retune. Gonna be fun when it’s back!
