i would like to know if this is a common problem i sealed the air filter up but no luck water is still coming in at the floor board any suggestions
i clean the drain that runs along with the fender did i not put enough sealant on to it ??Did you completely remove the old foam gasket on the back of the cabin air filter housing and clean out the drain along the top where the fender meets the shroud? A thick bead of RTV sealant around the housing is usually enough to completely stop the leak.
i clean it sanded it slightly to get all the residue off i am a little confused about the drain hose where is that locatedDid you cleaned drain hose or just add sealant to gasket line?
where is the drainhose located i see the drainage the runs along the fender but no hosei clean the drain that runs along with the fender did i not put enough sealant on to it ??
no i didnt clean that out what should i use to clean that out first i have to find it lolDrain hose is under air filter casing under hood.
It is about 4*7 cm and it has flap on bottom. Hose itself is about 8-10 cm long.
i think i know i felt that flap but i also broke it of just by touching it if thats the drain hose u can kinda of reach it barelyno i didnt clean that out what should i use to clean that out first i have to find it lol
