Have a 08 9-3 2.0T sport combi. A couple of weeks ago my driver's side window startied getting wonky. It goes down fine. It goes up fine but whether you hold the button or hit the auto up, when it gets to the top it doesn't stop, but goes back down about a third of the way and stops. It will stay up if yoiu don't quite go all the way. It doesn'happen all the time but lately about 90% of the time. ANy thoughts?? Thanks in advance
Could be one of two things. You probably have something stuck in the upper part of the window track that the windows hits when it fully closes. The anti-pinch kicks in and rolls the window back down. Check inside that track at the top to make sure it's clear.
If there isn't anything in there, you'll have to reset the anti-pinch protection on the car and it should clear up your issue.
