So I pulled my radio, hoping I could fix the wonky-volume problem I've been having - tightened all the screws, made sure all connections were tight, and soldered a loose connection in the back.
Plugged it back in, and go to enter my radio code...2_2_...except my '2' button isn't working now. Other five work, just not the one I need.
Huh. It's always something, isn't it? :roll:
Tried all combinations of pulling fuses, cycling power, and no joy.
After an hour of futzing with it, I held down the 'BAND' button while turning the power on, and the radio sprang to life! Don't know if this is normal, or if my possessed deck just thought it would throw one my way.
The radio appears to function perfectly now (except the '2' button)...and the volume control works. Time will tell if the 'fix' took.
