1 - 7 of 7 Posts
Took off the front wheels, and the offside has a stain on the inside of its rim, "that's not water" [condensation was my first thought] it's brake fluid! so a brief inspection finds the rubber dust cover for the nipple is damp with fluid too - it is weeping from there.
I checked it, it is tight but no proper seal.
I could be dirt lodged behind there from a previous bleed.
Fualty nipple.
worst case, failed seat in the calliper.
Needless to say I'm not pleased.
The V6, [the callipers were removed from a '97 Vectra] I going to get a new nipple this morning, hopefully changing this will 'purge' the area through.
Is there anything I may have overlooked?
i think you are on the right track, my guess would be a step has formed on the nipple so no longer sealing properly.
good job you noticed it :eek:
Changed the nipple, all seems OK now, wierd fualt though, I hope this is the last on this subject.
1 - 7 of 7 Posts
