I've heard this works and I am getting a purge valve CEL (from the t5 flash seqence). I can feel it ticking while the engine is running, so I think the guts are OK. Which way is it adviseable to blow the stuff? Even if it only buys me a couple hundred miles that is OK.
-Cm
Only when its warmed up-at the same time it runs a diagnostic 2x per run cycle and will only engage 15-85% full tank. If it detects a leak it'll send up a CEL-either a big leak or a small leak-the small ones are a PITA!
If the valve leaks or malfunctions, it too will send up a CEL.
-Cm
