1 - 20 of 28 Posts
I have a new winter project... I got a hold of a chevy th350 tranny and I am going to make an adapter plate to mate this transmission with a pre 1990 saab 9000 2.0l engine and install it into a chevy s10. I will try to post pictures as much as I can so maybe someone else can do this.
I want rear wheel drive and yeah Im tuning to maybe around 350hp I have a 2.0l engine sitting around. this will give me something to do this winter.
Auto vs. Manual? But once you're good to go with the auto, it won't take much to go to manual in the future. Sounds like a fun project. I'm building a turbo minivan this winter.
Discussion Starter #12
I might even spend a hundred bucks and get a neutral lock installed in the tranny. I'll set up a 2 step throttle too so I can launch in boost :)
Discussion Starter #13
well I have dimensions for the saab bellhousing thanks to lowbudgetrides.com but I need dimensions for the th350 bellhousing bolt pattern now. does anyone know where I can pick these up? I cant seem to find anything online.
The adapter plate you require should be availible off the shelf.....
In europe people with Pontiac Fiero's tend to do a Vauxhall engine swap and put the GM Red Top 2.0 16v engine into the Fiero. And as far as i know the Vauxhall lump has the same bolt pattern as the Saab engine.
You should find the bits you need on the FieroStore website.
Discussion Starter #18
well... I found dimensions for both the saab end and the hevy end of my adapter plate. I milled it out a ouple days ago. I will post some pitures ASAP!
Discussion Starter #19
I found an engine that will fit my adapter plate. only problem is that it is out of a 1995 9000 cs NA. not the turbo CSE engine. Is there any difference besides the cams? I looked at the specs and the compression ratios are the same between the two engines. thanks
-kye
Discussion Starter #20 (Edited)
Adapter Plate Pictures!!!
ok well heres some pictures of my adapter plate. :D Oh by the way... this bell housing if off of a muncie m20 manual transmission. I just needed it to see if my adapter plate would fit. yes and I did forget to cut out a spot for the starter. no big deal though... Ill just trace out where the starter goes on the engine and cut the adapter plate where I marked it.
1 - 20 of 28 Posts
