Hi Guys
Hope your machines are running great!!!
I had a 'coolant level low' indicator on for last few months even though I topped off the coolant. Took it to a mechanic and he said I had a leaking water pump. I got him to change it. When I got back into the driver seat, I noticed that my saab was not revving the same (it revs as if I have an issue with my silencer..not silencer issue but seems like over revving..not sure if am explaining this correctly). I used to love the way turbo used to kick in and the way engine used to rev. When I asked the mechanic, he said they cleaned the turbo so give it a couple of days. Turbo - instead of breathing sounds like its exhaling...overall not happy at all!! Wondering if any of you have come across this? If yes, would appreciate if you can share what the issue is. Added to this, I also have check engine light on after couple of days. I need to take it to mechanic to check whats going on but want to do some research on existing issue.
I also have had 'Stability Control Failure. Contact Saab Dealer' warning on my SID for last 3 months. It shows up whenever I start the car but there is no issue with performance of the car. Any ideas what this might be?
Since I got my car back from mechanic, I also have 'Lock system failure. Contact Saab Dealer' warning. Too many warnings..
I love the way my car drives even after 132K miles on it. I am hoping these issues will not be a big hole in my wallet.
I appreciate your response and thanks in advance.
