Just noticed that there is an inside water trickle leak from the roof down the rear area of both driver and passenger windows. I was able to replicate the leak with a hose to the windows. The windows do appear to be sealed well to the roof with seal rubber in good condition.
How common are these sort of leaks in the convertible?
Is it likely to be a window or roof alignment issue?
when cleaning and pointing a hose at the seals, i can also produce "water trickling down on the inside".
since this is a very unrealistic situation, i have never experienced any water leaking into the car under even the harshest weather conditions.
if you point a high pressure hose at any other seal of any other car, especially convertibles, you will have the same result i think
additionally, you can minimize this occurrance with a good application (cleanly) of clear silicone grease (available at your local hardware store) to all the seals.
