Howdy all.
I have just had the Aquamist 2D system installed on my 2002 93 HOT Vert and all I can say is WOW.
I was a little sceptical as to whether or not it would make a worthy improvement to performance, but I am blown away.
I am running BSR Stage 3 with 3" DP and exhaust (no Cat).
The fact that I am at high altitude and that the best fuel we get is 93Ron really made the Aquamist system seem like a good idea. We are also blessed with amazing weather down here (but not for turbo performance), Its the middle of winter and it was 24 degrees Celsius out today. Its nice to be able to use my Vert in winter:cheesy:
My car now boosts the way it does on really cold days (3 degrees C) All the time even when its close to 30Deg out. The power also comes in a lot stronger lower down the rev range and holds it there (17.5psi) all the way to red line. I am running a 30% Methanol mix in the water which also give it a little extra.
The detonation problem I had after upgrading to stage 3 is now completely gone. Its amazing to see that after a few hours of spirited driving the inlet manifold is cool to the touch.
So if you live in a hot climate or at high altitude then don't hesitate its worth it.
more info here http://www.aquamist.co.uk
Jules
Jules
