The internal Return (hold Shut) spring on the actuator may have deteriorated An inevitable occurance.
BUT it may not be what yer problem is.
Suggest doing a Base Boost Diagnosis.. as specified in the Bentley Manual (use the C900 one).. identical procedure.
You might also try a 'helper' spring on the actuator.. a simple inexpensive spring bodged between the Actuator and the Wastegate Flap rod (which incidentally Has no resistance whatsoevrr designed in).
