Hi I have a 1998 Saab 900 turbo convertible. I’ve finally gotten most of the issues sorted out and the car is looking great. The only thing that remains is the window washer pump wiring.
Could someone help me with where the wiring should go??When I got the car the window washer pump didn’t work. Upon checking I noticed that the positive side of the wiring was disconnected. I can not find where the wiring goes! I’ve temporarily connected to the horn so as silly as it sounds when I honk window washer works!
because this is so annoying I’d like to wire to the correct wire that comes from the washer switch. Could someone show me a photograph and point out where that wire comes from? I’m not good at reading schematics and so a photograph would help me a lot.
thanks so much everyone!
The washer pump works. It’s just a matter of connecting to the wire that comes from the washer switch on the steering to the pump motor. I know it should be close to the pump/washer tank but I can’t tell which one it is.
