Hi all, had a good search here on this but n0-one seemed to have the same issue as im having at the moment. Basically my wipers are working fine, on all levels. When I pull on the lever for the washer fluid, the wipers work fine but no fluid on the windscreen. There is no sound from the pump. However, if I pull on the lever (i think its every fifth pull of the lever??) the pump will work and fluid will dispence from the headlight jets. So, all in all, windscreen washers are not working, headlights are.
I have checked fluid levels and it is fine.
I have checked both fuses and they are fine.
Anyone have any suggestions? Older threads with similar (but not identical) issues seemed to suggest that it is the wiper motor and that the wiper motor and washer pump are somehow linked. I'm far from an expert here so any help would be appreciated. If its the wiper motor on the blink, Ireland is not a country one can do without wipers!!!
