Accdently psoted in 9-5 section...
Driving along the highway yesterday, center dash stack lights (not sure about radio, it was off) go out for a few seconds come back on, happened again about 10 minutes later. . Third time stayed out, Automatic Steering lock failure warning comes on SID. Looked down and ASL light on shifter is flashing. SID then reads Checking.... Then all returns to normal.
Before this I had a few times where the lock did not disengage when putting the key in, but took a second and then did.
Side note, the tires started buzzing like truck tires on the highway. (2000 miles on new Sumitomos which are usually very very quiet, have bought for my 9-5 a couple of times) up front about 100 miles before all this. Not sure it's related, going to get it aligned
Read aobut CIM in other threads but none said anything about dash lights flashing or gong out at the seam time.
Dash lights are powered via BCM.
Had similar with my 9-3 Vector Sport several years ago. Changed the electrical switch unit which is located under the ignition switch body.
