1 - 2 of 2 Posts
i got the rack and pinion installed about a month ago. shortly thereafter the abs, tiangle with the squiggly thing in it and the esp lights came on. The steering will controls are all screwed up. Do you think the tech hooked everything up *** backwards. and what do those lights mean?
Could just be the ABS unit failing. Very common problem BBA remain rebuilds them. Check the connections to the ABS unit and make sure they are tight. If they are your ABS unit needs rebuild.
Steering wheel controls not working would make me think your clock spring is in need of replacement. I think there is a recall on the clock spring.
1 - 2 of 2 Posts
