Have you considered adapting Bosch 0438170031? It's for Porsches, but should still work and is still available.
You might also look at:
At the end of the day, the guts of the accumulator don't vary much... it's just pressure and volume, and I'm betting there isn't a huge variance there... maybe none that apply to a Saab given it's a smaller motor running standard pressures. The bigger issue is probably going to be shape and fittings, but you should be able to make adapters, or replace the ends on the factory lines (although it'd be a little painful!).
I just found a 0438170001 and installed yesterday. It can replace 0438170047.
Thank you very much for replying to me.
