Voltage regulator -update- need help
hey everybody
So while im driving my battery light comes on and my voltage will dip from ~13.9 to anywhere from 10.5-12.5. It's getting worse. I am going to order a new voltage regulator. Will my car be OK driving a lot until the part arrives? (does the VR take a while to fail or can it be sudden?)
thanks
"Will my car be OK driving a lot until the part arrives?"
Probably not, because you're running on battery charge only and it will drain after 1-2 hours especially if you have the headlights on. If the charge red light goes off sometimes, that means the battery will charge up a little and allow you to drive a little longer.
The VR takes a short while to fail and it gives warnning signs like the charge light going on (but it could be burnt out) and the voltage dropping to below 12-13V.
My advice is not to drive untill you replace the VR or you may be stranded.
The voltage regulator is combined with the brushes and bolts to the back of the alternator. In the U.S., Eeuroparts currently shows them in stock from 3 manufacturers, this is the least expensive:
Though I'd probably be inclined to cough up a bit more and get the Bosch regulator:
(The "Genuine Saab" item is ludicrously expensive and appears to be the Bosch unit.)
I seem to be having the same problem. I cant find a VR for a 97 9000 CS. Is it separate from the alternator?
The VR - including the brush set - is part of the alternator, but is a renewable part. It is under the plastic cover on the inboard side of the alternator. It's most likely worn brushes that are causing voltage fluctuation. The VR/brush set is available from many places. For example, Eeuro has a Bosch set for $60:
269596
To replace, it is really just a matter of making a few simple removals and then, when you have some room, it's not bad at all. You reach down between the firewall and the engine - release the two wires, back out 3 small screws, pry the plastic cover off the inboard side of the alternator and the regulator is right there. Two more screws and it's out.
Pop the new set in - and button up. Two hours tops.
269597
