My turbo went a few weeks ago. Felt a pop, then a scraping noise coming from belt area and then a smoke show started. I had just left work and limped back to the parking lot. Started to hear a knock and shut her down until I could tow it home.
The engine always had a slightly off sound, a feint rumble at certain rpms which I could never trace but thought was balance shaft bearings. Oil pressure was acceptable but on the low end. I had previously replaced main and rod bearings which were not bad at all but I was already committed.
When I did the bearings I found a 1/8" strip of metal about 3/4" long that had a slight curve to it. The metal kind of resembled a bearing but the diameter was way to small to be any of the engine's bearings. I could not figure out where it could have come from and hoped PO had dropped something in the sump and the magnetic plug caught it before it could do much damage.
I pulled the engine then the head and the timing chain cover last week to grab the new chain and guides. When I pulled the timing cover a similar but longer 1/8" strip of metal fell out. Then I noticed that the balance chain sprocket had "separated" - the backing that is stamped or welded to the sprocket was hanging on the mounting spindle and one of the metal rings or spacers that are on either side of the sprocket was missing (the unidentified bits of metal I had found!). There was a good deal of slop in the idler sprocket and the exhaust balance shaft sprocket had a noticeable bend in it's outer plate or cover so one of the pieces must have ground through that sprocket.
I'm guessing that was the source of the rumble. I had installed a new timing chain kit - but I cannot recall if it included a new idler sprocket or not. Kicking myself for not noticing any defect in the idler during the install.
It's the old chicken or the egg conundrum, what came first - balance chain failure or turbo failure. Either way the result was catastrophic. One piston is loose in it's cylinder (can be rocked back and forth) and I have not had time to pull it to see what's up with that. The cylinder does not appear scored which is weird, so maybe the quick shutdown saved the block.
I'll try to post some pics this week. Seems like a strange part to fail. I'm kicking myself for not deleting the balance chain when I did the timing. I've done the delete on a 900 and 93 but got nervous about some of the posts on deleting the balance shafts on a 2.3. However, I'm going for the delete on the engine that's going in next. I'll post the results of that at some point in the future.
So a bit of advice when doing a timing chain - check the balance chain idler sprocket carefully!
