1 - 2 of 2 Posts
anyone have any idea what would cause the following problem? my cabin fan won't stop running, it runs at full speed all the time, even if I turn the car off and take the key out of the ignition, it will keep running till the battery is dead. I was thinking it was probably the resistor, but wanted some other opinions before buying one. If anyone else has experienced this, any input would be much appreciated.
I'm going to assume its Auto Climate control and not Manual? You can start by pulling the fuse on the side of the dash labeled "C". that should stop the fan from running.The problem is probably with your fan control module located on the passenger side behind dash, attached to the air distribution box.
1 - 2 of 2 Posts
