1 - 16 of 16 Posts
Quick question, I have tested my BPC by doing 2 tests. On test 1 i disconnected the BPC electronically and took it for a drive. I was getting 1 pound. Then i plugged it back in and took the 2 bottom hoses and spliced them together. I took it for a drive and i was getting 6-7 pounds. Is that whats suposed to be happening? I did thise because i have a issue on full throttle where my car jerks violenty under acceleration. I have a stage 1 JZW tune on the viggen.
Disconnecting it electronically should give you base boost (6 psi on my car), not 1 psi!
I don't remember what order the hoses are in -- which did you splice together in the second test? The compressor and wastegate?
What does the boost pressure look like without any changes to the BPC? What pressures are you seeing when the jerking happens?
The stage 1 tune should have removed the fuel cut at 15 psi, so that probably isnt' it...
what is the boost like when the BPC is plugged in electronically?
when you spliced the two bottom hoses together that's exactly what's supposed to happen 6-7 pis
i think your BPC is stuck open, that's why you are getting overboost
When my car is cold it runs fine! I can gun it and everything seems to work fine. After a little bit it starts doing it and it gets worse and worse every time I accelerate. When my car I cold and seems to run fine I get 20 pounds and then when it starts to happen it starts from anywhere between 14 and 17 pounds.
Sent from AutoGuide.com Free App
try a brand new BPC
i seem to have a very similar issue. once things heat up my boost goes down
Discussion Starter · #10 ·
Any suggestions on to what I should do? I did play around with the noise reduction valve and I noticed when I unplugged it it was making my bucking ALOT WORSE. Just a piece of information for you guys!
It's the one that connects the 3 vacuum line. 1 line from the diverted valve 1 line from the throttle body and 1 line from the intake manifold. The sensor sits on the back of the engine bay right next to the brake fluid container.
interesting. that thing controls the by pass valve only.
i by passed that thing on my car. i just have one hose going from throttle body directly into the by pass valve
Discussion Starter · #14 ·
Do you have NGK plugs gapped to around .035"? I have a JZW stg 4 tune on mine and it jerked violently at WOT until i gapped my plugs to around .035" and they were at .039" IIRC
1 - 16 of 16 Posts
