I ended up stripping the salvage yard motor all the way down since I had to replace the head gasket. The timing chain and guards were well worn and once the head was off I figured I might as well pull the pistons and crank and measure everything. The valve train, head, timing cover were exceptionally clean which made me think someone did some work before, each rod also had a "B" written on it in perm marker. Not sure why they did not do the timing chain - I would've dropped the engine right in if the chain was not worn. Pistons are stamped AB and the cylinders still have crosshatch so I'll probably hone at home and replace rings and replace crank/rodbearings. Maybe drop the head off to check for straightness, clean and replace one stud that broke 1/8" in the head, but don't think it even needs to be planed.
I am really struggling with the the balance shaft (BS) delete decision. Has anyone actually done a BS delete in a Viggen with stock mounts? I found posts where people say it's hardly noticeable and some that say it'll shake your fillings out of your teeth.
If I keep the BS, I might try to swap the timing cover from an NG900 with the higher volume oil pump. I have a spare and the outer ring gear but can't find the inner gear which is somewhere in the parts bin. It looks like you need to use the power stereing housing from the 900 and maybe grind a tab on the lower left of the housing down by the intermediate shaft mount.
