1 - 2 of 2 Posts
So I guess this is not that big of a problem it is just a little annoying.
Every once in a while and I am thinking about once every month maybe twice a month the alarm will go off when I stop the car and take the key out. Then the only way to shut it off is to put the key back in the ignition and turn it. Then when I take it out again the alarm will start going again. This continues for a while until it stops or I fiddle with the glove box, normally opening and closing it or pushing on it. I have taken the glove box out as and there is no electrical connection to in except for the light. Is there something else that could be causing this? Could it really be because the box gets a little bumped and causes the alarm to go off? And if so how would I fix the problem?
One ,IMO, will need the complete electrical schematic just to troubleshoot this, without time consuming and expensive parts throwing..
The ignition switch may be fault, but this must be proven..
1 - 2 of 2 Posts
