1 - 8 of 8 Posts
Hi all
I know it's now middle of May but just after the clocks changed in April the 'day running' lights on my 9000 went out. I have checked the fuse and that's OK.
So, is this a very clever feature or have I got a fault?
Any suggestions would be greatly appreciated.
Regards
Bryan
DRL run from the same fuse that backlights the instrument panel. Do you have instrument panel lights? If so, then fuse circuit must be OK, if not then fuse circuit is the problem.
DRL don't work if headlight switch is set to headlights or park lights.
Hi Super
Yes, I have instrument panel lights and I understand that the light switch has to be off. The day running feature was ON all winter then, just as the clocks went forward, it went off!
Bryan
In Canada (and the US) they do. This was initially annoying to me because I don't like DRL's as they only illuminate the front of the car. I took out the fuse and the instrument panel backlight went out, which is a feature I've always liked about the 9000. However, the silver lining is with the instrument backlight out I am reminded that my lights are not on when i drive in the city at night.
1 - 8 of 8 Posts
