1 - 7 of 7 Posts
If I have to do this one more time...
I follow the instructions in the WIS, I release the tabs with a screwdriver, pull gently and boom! The front comes off instead of the vent coming out. Fortunately I can put one back together in a couple of minutes.
Believe me I wouldn’t take it out if I didn’t have to. The vent kept jamming shut. This last time I discovered that the tab that keeps the control rod in the damper was broken off. I super-glued the ******* in and so far so good.
Have you tried any silicone or PFPE lube on the moving parts?
It only explodes when I take it out to fix something. (In this case the rod that controls the damper which kept coming loose.) But I fixed it now. Otherwise it works fine.
1 - 7 of 7 Posts
