1 - 2 of 2 Posts
Hi all, this is my first post on this forum and I hope someone can help me. While replacing a non-Saab leaking heater valve on my 86 900 turbo, I had to remove the dash and instrument cluster. The main ventilation selector wiring - well labeled I thought - went right back on like it was before (and it worked perfectly before). Now the blower is either OFF in the off position, or high/high in all other positions. This makes me think that there is a relay in there that has failed, and it fails to HIGH speed blowing. Does anyone have any experience with this? Or a wiring diagram for this 1986 900 Turbo? I appreciate any feedback or help.
On the Vent Selector switch, there are two micro-switches; upper and lower.
The high-speed fan is controlled by the lower micro-switch. There are 3 terminals on this switch. You either have the wires on the wrong terminals or you accidentally bent the actuator arm on the switch a little.
Fiddle with that lower switch and its wiring until it works right.
1 - 2 of 2 Posts
