1 - 11 of 11 Posts
I am looking for a vacumm diagram. I pulled out the engine and rebuilt it but cannot remember where all the hoses go. Could someone help me . Please and Thank You
As far as i can recall there is no such thing in WIS or EPC. Did you not take photos or make notes where they go?
no, it does exist on the WIS. I'll see if I can find it tonight when I go home.
Do you know what vacuum lines you've disconnected ?
All of them...........there are seperate pictures of various parts of the engine vacuum system but no picture that covers all lines.
I was trying to figure out what lines went where off from the throttle body but i think i fugured it out. I went to the dealer and got pics of ummm some of the lines. Now i get fuel spark and crank but no run. What a POS. I hate this car. But anyhow thanks for the help.
...You took it apart... :roll:
that's the diagram... it might not be obvious for you relate to every part unless you know how a turbo works (i.e. what vacuum lines individual functions is) so maybe you could find a buddy with a 9-5 to compare against ?
Good luck .
Well - I've never even thought about pulling an engine out, and I was able to make sense of everything except the airflow directions surrounding the evap and purge valve. (Is the check valve on the left oriented in the correct direction?)
Pyakit - What do you think?
1 - 11 of 11 Posts
