1 - 2 of 2 Posts
Hi Guys, Is there a secret to getting the vac tank out of a rhd 88 vert? It appears that I have to bend metal to get it out which I think would not be very Saab like. There are damaged fins? on it already from the PO :nono;
There is also a double pin connector with red/white and black wires near it which disappears into the firewall wiring harness. It appears to have been used but I cannot find anything it connects to. Any ideas would be appreciated. Thanks in advance.
try pulling it out toward the front of the car on an angle (kind kind of drag it along the top of the wheel arch, thats how i have removed all of mine. you may have to unbolt the power steering reservior though, pulling the vac tank straight up wont work.
as for the 2 pin connector, it most likely connects to the side indicator repeater. the light holder twists out of the housing, remove the holder, connect the plug to it and refit it to the housing ;)
1 - 2 of 2 Posts
