Your best bet may be to get the WIS.
Thanks, my problem is coolant in the exhaust, no real signs of it in the oil. I am beginning to suspect that the coolant is getting through the turbo seal and into the exhaust. I will be checking this out in the next couple of days. I was asking about the head gasket procedure because I thought I might need to go in that direction and was not finding any good instructions and did not know how long it would take to find them.If you're trying to fix a problem of coolant mixing with oil what you most likely need is a new oil cooler, not head gasket. Make absolutely sure that head gasket is blown before ripping the V6 apart. Oil cooler is a much more common issue.
