I am very new to 1969 Saab Sonett ownership and have sme questions which I hope can be answered by knowledgable members of this forum.
I am awaiting brake pads and caliper seal kits but wanted to run the engine periodically to keep the battery charged and everything lubricated.
I checked the timing and it was very far advanced above 6 degrees BTDC. I will use Jack Ashcraft's timing methd when I can someone to help.
Question 1 With the car up on jack stands and the front wheels removed and pads removed from calipers with the trans in neutral and engine idling at 800-1000rpm the front axles rotate. I can easily stop one axle at a time from turning with my hand. Is this normal?
When I place the transmission in freewheel in this same situation the engine races up to about 3000RPM !
I obviously don't let it rev this high for long but I am curious why this happens.
The transmission shifts nicely through the gears and the clutch seems to work fine. I have never driven the car with the freewheel engaged. Thanks for any help you might offer.
