1 - 7 of 7 Posts
Location - additional details: Syracuse, UT
Means of contact: Post/PM
Price: $125 Shipped with in the Continental United States
Transmission Type (auto/manual): NA
Mileage (miles/kms): NA
Description: I have a used ESID2 out of my recently totaled 07 93SS. Used it for about a year and a half. The added functionality is a must. Currently it is set for three blink incase someone wants to use it on an SS prior to MY07.
A new one will set you back about $175
eSID - extended Saab Information Display
The eSID2 is the second generation of a small tool that enhance the Saab driving experience on Saab 9-3 MY07 and newer cars by collecting internal hidden car data and present it to the driver on the built-in SID (Saab Information Display) located in the instrument cluster.
It is easily installed under less than a minute and focuses on Integration in existing vehicle functions and providing a range of new functions:
  • Three-Blink when touching the turn indicator
  • Selectable Welcome Message
  • Momentary Fuel Consumption
  • Accumulated Fuel/Distance
  • Average Fuel Consumption
  • Manually controlled Wiper interval function
  • Torque/Power
  • Turbo Boost Pressure
  • Air mass
  • Tire Pressure
  • Drive Time
  • Engine Coolant Temperature
  • Intake Air Temperature
  • Ethanol Blend
  • Automatic Gearbox Oil Temperature
  • XWD Oil/Clutch Temperature
  • Acceleration Performance
  • Crank Voltage
  • Read/Clear ALL DTC’s in the entire vehicle (not only OBD)
  • Diesel Particle Filter Status
  • Set System Clock if using non-OEM radio/navigation
  • Automatic activation of Fog lights in Parklight position
  • Automatic activation of Fog lights with Full Beam
  • Metric/Imperial units
It is perfectly integrated with the vehicle and is controlled using the normal steering wheel switches.
The unit is sold with a OBD-connector housing and can easily be mounted/removed from the vehicle within seconds.
More information, instructions, and demo videos can be found at: http://www.esid.se/order.html
Pictures (embedded pics or links to external albums are mandatory):
1 - 7 of 7 Posts
