1 - 11 of 11 Posts
Sorry if this has been posted a million times. I looked through the thread stickys and didn't find any mention of a go to brand of serial port adapter to connect a Tech2 to a Win10 x64 system.
Thanks
I paid 29.00 at a local electronics parts store in Newington, CT for a cable made by Manhattan. The guy said he has sold 1,000 of them and never had one not work. It worked for me.
I took the advice of using the Keyspan High-Speed USB to Serial Adapter (USA-19HS) when setting up my XP machine for TIS2000. It worked first try. Just make sure it is set to COM1. Thanks dspargo, great advice.
Found working and cheap usb adapter for tech2 (UGREEN 20210 USB Serial Cable)
amazon.co.uk/gp/product/B00QUZY4UG
Working with tis2000 and globaltis for gaining security, working with russian card writer.exe to flash bin files on pcmcia cards trough tech2
what else should i check? seems like a good £10 alternative
Just wanted to add this one to the list here, worked perfect on a Windows XP 32bit pc, didn't have to load any drivers. Was able to connect fully with the Tech 2
Sabrent USB 2.0 to Serial (9-Pin) DB-9 RS-232 Adapter Cable 6ft Cable [FTDI Chipset] (CB-FTDI)
I'm using a $7 no name eBay adapter that came with drivers. It works fine from VMs too. It seems the issue isn't that critcal these days.
Bought this one, drivers are easily downloaded (I did that out of habit, didn’t think to try without downloading them) & worked like a charm. FWIW I have a Windows 10 64bit computer running VMware with a Windows XP 32bit virtual desktop
1 - 11 of 11 Posts
