61 - 68 of 68 Posts
All true photousa, we learn each time. And always an excuse to buy a new tool! But I know my limits, which are more than yours I believe. FYI just had mine done about $150 each side for labor
I think that's actually a good deal on labor based on my experience. It took me two hours to rebuild one side and I failed, so I'm going back to get it right the second time. I was also surprised to find that my bumpstop was completely destroyed which cost me a little time to get a generic replacement. That was in a rental garage costing me $30 per hour, so it wasn't a free lesson.
I ended up taking both front struts apart for a second time on my 2000 to replace the bump stops, bearings, and a mount that I had to reuse. I bought a pair of Monroe strut mounts, and one of the nuts snapped right off when I started to thread it. I had to reuse one of the old ones to get the car on the road, but of course that was the cause of a creak on the left side of the car. The car had a creak on the right side after I moved that mount to the right. At least removing the struts and rebuilding them is pretty quick on these cars once you've done it a few times. :cheesy: It's a walk in the park compared to doing the same job on a NG900 or OG9-3. If anyone else needs bump stops, you can get Rein versions from RockAuto for about $3.00 each. They're slightly taller than the originals on my 2000, but they look about identical to the ones that Saab sells now, if not identical, and they're made in Germany.
Interesting notes on the rebuild process. I used the Uro "Black" mount which comes with 12mm bolts instead of the 10mm used with the stock mounts, it also ships with a really cheap bearing which I did not use. The stock mount that came off of my "03 was the Silver, (dome looking) version with 10mm bolts. I also put in the new stock, French made bearing and a new zinc disc. As a last minute solution to my destroyed stock bumpstop I had to use the Monroe bumpstop, which I had to hollow out because it's not designed as a direct swap.
Now that the setup makes an awful sound and feels terrible, I'm switching to the Silver Uro mounts, (which I have to tap myself) & the Rein version of the bumpstop. Btw, if anyone needs to know the Metric tap size for the untapped Uro Silver mounts it's 8 x 1.25.
I believe that in 2002, when Saab slightly redesigned the front struts, they switched to silver strut mounts themselves. Those are actually still available from them, unlike the older black ones, which are on backorder or no longer available. The 1999-2001 OEM strut mounts also used M8x1.25 bolts, and so do the Monroes. I remember reading a post from someone, possibly in this thread, who used whatever bolts his aftermarket mounts came with and they made a lot of noise because the bolts were too long and rubbed on part of the strut, causing it to not rotate smoothly. I reused my car's original bolts since the Monroe mounts I bought didn't come with any.
Good to know, maybe the bolt is one of my issues, but the replacement bolts didn't seem abnormally long to me.
I installed the black version on both of my 06' saabs with no issues at all.
Taxicavenger, did you use the URO bearing that came with the kit or did you use the SKF?
My 2006 SAAB 9-5 is in desperate need of a driver side strut mount and bearing set. The Koni mount/bearing lasted less than 30,000 miles.
Discussion Starter #68
SKF. The one that came in the kit seemed inferior in build quality imo.
61 - 68 of 68 Posts
